Get clocked Challenge
2»
  • Voyager
    Voyager Posts: 403
    GW said:
    ahhh I misunderstood, so if the place is dropping, then you nailed it- you need more heat. I didn't catch that.
    I think there is plenty of heat, but the thermal mass of the slab simply can’t be overcome. It would take some sophisticated controls that looked at the weather and tried to anticipate the temp drop each night and start putting heat into the slab hours ahead of time and anticipate the temp rise in the morning so the heat could be turned off a few hours before sunrise.
    By the time the simple wall thermostat sees the temp change, the slab simply can’t respond quickly enough. Just the nature of the beast with concrete radiant.
  • GW
    GW Posts: 5,255
    edited February 2021
    OK, I think I understand. You’re doing a basic on off thermostat. I really dig the constant circulation for large mass, radiant. I’ve done a lot of Bosch and Viessmann. Pretty easy to set up indoor feedback to the boiler brain. Your boiler, cannot do?
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • Voyager
    Voyager Posts: 403
    Yes, basic Honeywell on/off thermostat. Not sure what you mean by constant circulation with indoor feedback.
  • GW
    GW Posts: 5,255
    Well that’s what you need. No more on- off, just “on” if the outdoor temps are below x
    if you’re boiler isn’t smart enough, look at Tekmar.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • Voyager
    Voyager Posts: 403
    Not seeing how that helps. Do you mean constant circulation and variable firing? Or constant circulation and firing?
  • GW
    GW Posts: 5,255
    It might be goos to start a new thread “constant circulation pros cons” or something to that effect. Others can probably explain it better than me. You want to keep the pump going non stop and the boiler just comes on as necessary. If you stop the circulation. The whole slab cools off and you’re in a viscous cycle, wasting energy. You do have an outdoor sensor right?
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • GW
    GW Posts: 5,255
    Fast Forward 5 years, my house must be losing heat or the gas co has changed the gear ratio on my one year old gas meter— 78 seconds for 1 cu ft, 46,000 BTU. 5 years ago I clocked 38,000. Humphhh, not sure why there's that much difference
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    GGross
  • GGross
    GGross Posts: 2,062
    Check your boiler stack temp against the supply water temp see if there had been a drop in burner efficiency? maybe needs a cleaning?
  • GW
    GW Posts: 5,255
    @GGross I'll stick my machine on it and see if the temp diff changed. I haven't opened it in a bit
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
