Ceiling Radiant - Exposed
Living space below - roof above. Long time customer always complained that this room never heated well. And now - after they nailed the tubing - we get to see why.
No insulation in the ceiling; just that reflective paper that you see there.
Someone needs to put some insulation above that tubing.
The roofer was a good shot. Probably 5/8" od tubing and he got it right between the eyes. What are the chances. Dead center!!!
Or was the nail from below?
Looks like from below, like someone was trying to hang something from the joist.
now they need someone as good as you to match the texture of that ceiling
The biggest favor you could do those people is to trace the pipes back to floor level, cut them and put in a panel radiator.
Then hook them up with a good insulation guy and a drywaller. Take the ceiling down and redo it.
Great suggestion, but my favors don't go too far past my pocketbook. That's a big job and I don't think they could afford it. That's a mid five figure job in this area.
Two btu per sq ft for degree difference for a slab0
- 50 Industry Classes
