Ceiling Radiant - Exposed
Alan (California Radiant) Forbes Member Posts: 4,665
edited 1:15AM in THE MAIN WALL
Living space below - roof above. Long time customer always complained that this room never heated well. And now - after they nailed the tubing - we get to see why.
No insulation in the ceiling; just that reflective paper that you see there.
    EdTheHeaterMan Member Posts: 11,766
    Someone needs to put some insulation above that tubing.
    mattmia2 Member Posts: 16,046
    but can you, or would it interfere with how the roof works, does it need ventilation below to not cook?
    snowmelt system for the roof.
  • kcopp
    kcopp Member Posts: 4,642
    Slick patch! So few people solder any longer.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,036
    Snowmelt for the roof where it almost never snows 🤔😁 And nary a scorch mark on the wood behind the tubing👍
    Yours, Larry
    ps, Maybe when they reroof, some foam board can go under a new roof deck…
    EBEBRATT-Ed Member Posts: 19,908
    edited 2:20AM
    The roofer was a good shot. Probably 5/8" od tubing and he got it right between the eyes. What are the chances. Dead center!!!
    Or was the nail from below?
  • DCContrarian
    DCContrarian Member Posts: 1,433
    Looks like from below, like someone was trying to hang something from the joist.
    now they need someone as good as you to match the texture of that ceiling
  • DCContrarian
    The biggest favor you could do those people is to trace the pipes back to floor level, cut them and put in a panel radiator.
    Then hook them up with a good insulation guy and a drywaller. Take the ceiling down and redo it.
