Can anyone please help me identify replacement mixing valve?
galaxydog
galaxydog Member Posts: 2
edited January 25 in Radiant Heating
I have a cast iron hydronic radiant floor heating system built about 25 years ago. After speaking with two different heating techs, I believe my mixing valve needs to be replaced. I don't have the $2k+ to spare for the job, so I am looking at changing it out myself. I was told it's a 1 1/4 " size. I don't see mixing valves that look like mine online though. Where mine (no labeling) is large and extends in the x, y, and z axis, these one's online seem compact and extend in the x and y axis. Can anyone please help me understand what part I need to replace it with.
IMG_2004_result.jpg IMG_2005_result.jpg IMG_2006_result.jpg IMG_2002_result.jpg
    hot_rod Member Posts: 27,237
    Heatway sold that valve as the AllTemp 2. It had an orange label on top. I'm not remembering the manufacturer. The smaller mix valves they offered were Hoffman.
    The is somewhat similar to the Watts 170, perhaps an earlier version.
    If it still controls? the o rings could be replaced. If the small heat motor "pill" inside is bad, you need to find an OEM part
    bjohnhySukhoi29SUSteve Minnich
    I actually still have a cut away of that valve. Only 2 o-rings inside, both at the top nut and around the stem. The valve mechanism itself is brass on brass.
    Looks like someone tried to scratch out the name Watts on the bottom cap 😲
    Screenshot 2026-01-25 at 11.54.00 AM.png Screenshot 2026-01-25 at 11.53.50 AM.png
    bjohnhy
  • galaxydog
    Hello hot_rod,
    I am sorry for the late reply. Life threw me a major curve ball.
    Thank you so much for responding to my post. I really appreciate your time and efforts.
    I haven't been able to find this exact part. I also have trouble finding a replacement part.
    Could you please suggest anything that could work?
    EdTheHeaterMan Member Posts: 11,948
    edited February 18
    This might work for you: https://www.supplyhouse.com/Caleffi-523178A-1-1-4-Sweat-High-Flow-Thermostatic-Mixing-Valve-7-6-CV-Lead-Free
    there are less expensive mixing valves but they may not be adjustable to the temperature you need for Radiant floor heat. @hot_rod may have a better choice for you.
    unfortunately I don’t know if any other with that connection orientation
    I am almost certain that is a Watts N170 valve
    It has been replaced with a LF model, lead free, and looks a bit different.
    There were repair kits available for those legacy valves
    A rebuild kit is a lot less $$. That is s pricey valve to replace with a like version
    The Watts website shows part numbers and kits for discontinued products Find the repair kit # and check e bay a lot of old inventory ends up there.
