Frozen valves on early vacuum system
please advise -how to loosen stem. What tools what I need to remove the valve.
does that top stamped piece pull up and off or unscrew? don't force it but see if it comes off
it is . Tried several times to loosen but can’t get it to budge. Would a impact driver and 3/4 socket work to remove it. Any suggestions where I can purchase a new valve.
@magewick what do you disagree with? someone, i think it is
tunstallmakes a metering valve. you can also do the same thing by metering the steam with an orifice plate in the union.*mepco
if you take the valve off and work on it on a bench with a vise maybe with soft jaws you have more options to coax it to come apart in one piece but that is more of an off season project.
The MEPCO SWRF valve is another option.
Consulting1 -
i had the wrong steam manufacturer
weird they are in gr when it is so hard to find someone that understands steam in michigan
- 50 Industry Classes
