Indirect fired water heaters burnham
looking for 2 -70 gallon indirect water heaters burnham does anyone stock n Michigan
    hot_rod Member Posts: 27,329
    Good chance that is a Vaughn tank, if you cannot find one under that brand name.
  • GGross
    GGross Member Posts: 1,842
    Why do they have to be burnham tanks? wouldn't it seem to be better to install something that is available from your normal suppliers that you already have relationships with and have local support?
