Levittown, PA Country Club 2 story home
incipi22
incipi22 Member Posts: 2
edited December 2025 in THE MAIN WALL
Hello, Um in need of a replacement boiler for my country clubber in Levittown, PA
thinking of a Weil Mclain WTGO-3R, MAYBE EVEN A THEROMDYNAMICS CWL-85EE
ANY SUGGETIONS ON TRIED AND TRUE WELL FITTING, MORE EASILY INSTALLED UNITS FOR MY APPLICATION. ORIGINAL REMAINS IN THE KITCHEN. THANKS FOR ANY ADVISE
  • ScottSecor
    ScottSecor Member Posts: 1,030
    We need more details. Is this a slab home with the original radiant heating system in the floor? Similar to the ones that i believe originated in Levittown Long Island (NY)? If so, I own a similar home in NJ.
    Personally, I would prefer to not have a oil fired boiler in my kitchen. They are noisy, have a large footprint, smelly (especially when serviced), and typically designed for larger homes. In addition if your oil tank and oil line(s) are original, I would be concerned. Finally, if you get domestic hot water from a tankless coil, there are better options today.
    Assuming there is natural gas available, I would prefer it over. More options, smaller wall hung units available. Much better suited for a kitchen installation.
    Start with a heat load calculation, this will determine what size boiler you need. Might want to use the "find a contractor" tool on this website.
    HVACNUT
    HVACNUT Member Posts: 7,402
    Its still the original boiler? Can you post pics? Please?
    EdTheHeaterMan Member Posts: 12,018
    After over 70 years you still have an original boiler ?!?! WOW!!! I would like to see pictures too!
    You can count on there being a few more options available then Mr. Levitt offered in the 1940s and 50s. If natural gas is not an option, there are some oil burner boilers that operate a lot quieter than others. Oil burner noise in the kitchen is a concern. You would definitely want to hear it operate elsewhere before committing to it in your own home.
    Steamhead Member Posts: 18,393
    ISTR @Ron Jr._3 replaced a lot of boilers in Levitt homes- maybe he'll chime in.
    Consulting
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,696
    I believe Peerless and Weil-McLain made a boiler to fit that space specifically.
    Retired and loving it.
    Alan (California Radiant) ForbesHVACNUT
  • incipi22
    thanks for input, radiant on first floor replaced w/baseboard. original heater is correct, the country club modeling a 2 story, customer has no access to gas, and I can't talk him into relocating unit. ill post pics later when I return to job, but thousands of these have likely been replaced, hoping to get a tip on the better choices
    mattmia2 Member Posts: 16,428
    were those ge boilers?
    In Levittown Long Island, I want to say they were York Shipley. Like 55 gallon drums with a burner. I've only seen a few in the late 80's, and I was just a helper at the time, so manufacture wasn't top priority on the learning list. I'd love to see pics and dimensions of the space.
