Maybe its just me...
Tom_133
Tom_133 Member Posts: 969
edited December 2025 in THE MAIN WALL
So over the past year I have installed 10-12 GV90+ boilers, in different sizes. These are my go to boilers for lack of problems, and ease of repairs. They last, and typically give me very few issues.
Sadly though in those 10-12 I have replaced the rectifier plug, 591-391-985 on 4 of them. So I ordered 4 but many places seem to be out supplyhouse.com being one. You think it was a bad run of them?
Is it just me?
https://www.supplyhouse.com/Weil-Mclain-591-391-985-Wiring-Harness?srsltid=AfmBOorTGLKaq8YXD96rHwfIj6hvm5KuBdWfSkwQhP4yEig68OcPWbZz
Tom
Montpelier Vt
bjohnhy
  • kcopp
    kcopp Member Posts: 4,641
    It would Not be the 1st time a mfg supplier had a bad run of a part.
  • HomerJSmith
    HomerJSmith Member Posts: 2,743
    I have had a bad run with Honeywell and Comfortair, but they stood behind it. Ask Weil-Mclain tech support for the parts while explaining the problems to them. Remember, flattery will gets you everywhere.
    109A_5 Member Posts: 3,690
    You would have to figure out what part of it is actually failing. Rectifiers, bridge rectifiers and diodes in that size ballpark rarely go bad unless abused. I would suspect bad connections inside that molded assembly where you can't easily get to it or inspect it.
    mattmia2 Member Posts: 16,007
    or manufacture by the lowest bidder that isn't actually making sure they meet spec
