Nest power connector
bigjoe1980
bigjoe1980 Member Posts: 16
Hello all,
Please tell me if I connected my nest power connector correctly to my new gas boiler. I only have two wire and no C wire. So I needed the nest power cable to charge my nest thermostat .
I connected the two black wires the relays the boiler to the R and W on the two white nest cables.
    109A_5 Member Posts: 3,683
    What is shown in the picture looks incomplete. The R, C and W have to be correct to the boiler wiring. When it is hooked up correctly it should work.
    Sometimes the terminals are labeled on the insulating plate.
    mattmia2 Member Posts: 15,982
    the terminals on the boiler might be labeled r g and c depending on what part the manufacturer used
  • bigjoe1980
    Here are some pictures of my nest power connector. My nest thermostat is making a buzzing sound when heating. I am getting heat and it's working but not sure why the buzzing. And not even sure if it's still connected properly but somehow getting heat.
    Well I don't know why it is buzzing. What is your boiler make and model ? If it is what I suspect, you probably need a relay for proper boiler and NEST operation.
    EdTheHeaterMan Member Posts: 11,747
    Buzzing is not good. you want to fix that.
    …on the other hand, if the thermostat is only humming, it is probably because it forgot the words. If you can find the right sheet music with lyrics and place it in view of the thermostat the humming may stop.
    bjohnhy
    HVACNUT Member Posts: 7,305
    Try switching R and W•Y on the boiler side.
