Zone dampers
creger.robert
Member Posts: 108
in Gas Heating
looking for 3-ZD16x8TZ dampers
Does anyone stock in michigan
Do they need to be Honeywell? Not that I know of any suppliers in Michigan. Just curious because any manufacturer will do.
24 volt 16x8
OK. Motor on the 8. It doesn't need to be Honeywell. It can even be a 2 wire damper.
yes motor on the 8
2 wire
