start problem
Amana gas furnace install 7/21
problem in intermittent. Sometimes, not all the time, the furnace will start and then shut down within a few seconds. will try again shortly. Will do this until the house is four or five degrees below setting. So far it has has eventually stared and the house warmed up.
Had tech in but it worked fine while he was here.
    109A_5 Member Posts: 3,983
    Amana gas furnace model ?
    Flame sensor ?
    Draft inducer proving ?
