Quick question regarding direct-vent water heater install
I'm looking to replace my 15-year old State water heater before the dead of winter hits.
My current penetration is circular, will that effect my options when it comes to water heater selection?
Would attaching the new vent-piping to the existing draft hood be a big no-no?
Here is a pic of my current setup
I ask this because from what I'm seeing, brands like AO smith have square/rectangular mounts. Am I just misunderstanding the exhaust setup?
P.S. the chromed-out copper is not my doing!!!!
I'm pretty sure the new ones are still a round pipe(3), but the termination (#1 the piece that goes outside) is a more square shape I guess. Can you post a pic of the new unit in question? AO smith, state, and American are all essentially the same water heaters btw, same manufacturer
The exact A.O. Smith you shared was one of the considerations. I was just thrown off by the squares in the #2 wall plate and termination as my termination outside is also rounded. I guess if the square mount for it covers up the existing hole I should be okay?
I had the exact same confusion about the “square” on the unit versus the round vent pipe. The install used a concentric kit through the existing round penetration with a trim plate. Important: don’t attach the new vent to the draft hood - it’s a different venting approach. I called Ferrer Plumbing and they checked the condensate slope, termination clearances, and equivalent length on the elbows per the AO Smith manual.
- 121 Chimneys & Flues
- 15.8K Strictly Steam
