Grundfos Pump Housing Temperatuire
I believe they rate their motors for a given temperature above ambient, not the circulating water temperature. Its usually listed on the motor.
Only way to know for sure if you are in trouble is to check the motor amperage. And even that isn't much help, because some of these little motors draw the same amperage with a locked rotor as they do under normal full load.
ME0 -
What Mark said - check the amp draw. The pump is rated for water temps in excess of 200*F.Steve Minnich0
Grundfos ups15-58fc with hot water heater for floor heat at 80F but pump warms up to 135-155F. I suspect air in system and will install t pipe at highest point in system to bleed air. Does this pump have bleed screw,?
if you pop that black label off, some models have a large screw below that you can purge some air.
Or loosed the top flange bolts and burp it. Be careful if it has been dead headed there could be a steam discharge
The checks can sometimes fail inside that volute and cause a blockage or restriction.
The motor will run a bit warmer than the fluid it pumps
Living the hydronic dream2 -
Hot rod..Ru from rogersville?
formerly, been in Utah about 4 years now.
Is this a system down near Branson by chance?
That looks like a fairly new pump, I think the PC indicates the 3 week of 2024 manufacturer date.Bob "hot rod" Rohr
1989 you installed a heat system in my 2 story house add on just s of hywy 60 off u hywy. Gypcrete floor one and heat transfer panels under second floor. I think you were building a subaru side by side for your son. I just built in eureka springs ark and troubleshooting new system. You were correct once you have a heated floor you'll never go without. Thanks for all your influence and help.
3
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
