Replacement Triangle Solo 60 Inducer blower pre 2010
the_physicist
Member Posts: 1
in Gas Heating
need to install replacement inducer blower on Triangle To prestige Solo 60. Replacement available is PTRKIT114. HAS 3 wire plug 120 VAC with ground. Is it backward compatible to pre 2010 model using Honeywell control board
PTRKIT114 is compatible with the PS series SOLO 60 boiler
if your boiler looks like this
