B&G air charger tank fitting
jpm659er
jpm659er Member Posts: 24
I haven't seen this model before. There is a nipple and cap attached to the bottom. How do you charge the tank?
  • leonz
    leonz Member Posts: 1,807
    The bottom cap is removed to drain the tank if needed and the valve is closed to allow water to fill the tank and create the point of no pressure change.
    EBEBRATT-Ed Member Posts: 20,164
    The tank will have either water or air in it. When you drain the water, the tank is then full of air. You then let boiler water into the tank to pressurize it.
    HVACNUT Member Posts: 7,434
    The pressure reducing valve charges the tank.
  • jpm659er
    edited November 2025
    that is how I would Service any traditional overhead compression tank when it gets waterlogged: drain it and close it back up and allow it to fill. I was hoping this "air charger" fitting would make the job quicker and easier somehow. Is it just a port to let air in while draining the water in the tank into the system?
    hot_rod Member Posts: 27,445
    jpm659er
