Blower motor for GV series 2
becca74
Member Posts: 2
in Gas Heating
I am needing some help on finding a blower motor for our GV Boiler series 2 and I’m not having any luck , I’m not sure if they have changed the numbers on it like they did with the control module and I read through other comments to confirm that was the case . Any help would be greatly appreciated
https://www.supplyhouse.com/Weil-Mclain-381-356-584-Blower-Motor-Replacement-Kit-for-GV90-Series-2-Boilers
One Pipe System0 -
thank you very much , the guy that came to work on my moms boiler was saying that the blower mower isn’t available anymore and trying to get her to replace the whole system and I’ve been on a mission to find the parts that she needs
Just verify if you can that what I found matches the boiler.
One Pipe System0
