It's cold in Ohio
Stillkickin
Stillkickin Member Posts: 5
edited November 2025 in THE MAIN WALL
I need a part number for the little gas supply line from the fuel control to the pilot light. Mine is 2 feet long. The tube is shown as part of the pilot light assembly in my Crown manual schematic but not the Supply House schematic. Latest part number for the pilot "nozzle" is Q314U1001. My boiler is a Crown, Aruba series, Model ABF-SPD. Old P/N is 146-62-092. Thanks Everyone. Never mind. The kit comes with replacement ends for that tube
    hot_rod Member Posts: 27,416
    Usually that is 1/4" aluminum tube with compression nuts on both ends.
    There are kits available to cut and make your own.
    Johnstone Supply is one of many sources. It may be less $$ and easier to find than the original OEM tube.
    Stillkickin
    EdTheHeaterMan Member Posts: 12,132
    Many other boiler manufacturers use the same part. Just bring it with you to the local plumbing supply company and see what they have that matches. you can use a longer one and just leave it coiled up. here is one that Weil McLain sells Pilot tube 560-742-865. it is about 3 feet long. Dress and act like you know what you are talking about. A 3 piece business suit is a dead giveaway that you are not in the trade. Clean running shoes are also not plumber attire.
    GrallertStillkickin
  • Grallert
    Grallert Member Posts: 1,113
    109A_5 Member Posts: 3,963
    Supplyhouse 146-15-005-70 may work depending on your boiler size.
    EBEBRATT-Ed Member Posts: 20,155
    @EdTheHeaterMan said"
    "Dress and act like you know what you are talking about. A 3 piece business suit is a dead giveaway that you are not in the trade. Clean running shoes are also not plumber attire."
    LOL. I don't hit the supply houses much anymore. I am sure they remember me but since I am retired 6 years they are bound to have some turnover.
    I still have a company hat and some shirts I can ware in an emergency LOL.
    Last place I worked we had an account at a local hardware chain for odds and ends. A former employee went to the hardware and spent 3k on chain saws and a weedwhacker and other stuff, after he left the hardware store notified the company of the unusual large purchase. They had this guy on camera, but it was blurry. I had never met him, but they finally figured out it was a short-term employee from 5 years before and he was caught.
    Apparently, he wasn't too bright.
    Where in Ohio?
    Do you have a Johnstone Supply or Graingers nearby? Those tube kits are typically on the shelf. Or any HVAC/ plumbing wholesaler.
    Probably find them on Amazon if you are a member maybe even get free overnight shipping.
    mattmia2 Member Posts: 16,692
    A good hardware store would have it too.
