System 2000 problems
flip975
Member Posts: 1
good afternoon I have a system 2000 boiler set up and I noticed the circulating pump is running continuously and the light is lit up for the thermostat and the water heating for the domestic water
Good afternoon,
Do you have hot water? Is anything over heating? Your plate heat exchanger could possibly be blocked.
Has the burner cycled on and off on temperature?
Robert W.
Energy Kinetics
- 116 Geothermal
