Electronic Mixing Valve
Home hydronic heating system with 7 zones including 2 radiant. Want to replace the manual mixing value for the radiant zones with a motorized value. I did the searching and see Taco has one but it doesn't allow setting the zone mix temperature / valve setting from a control signal. I can interface with anything so if its modbus, 0-10, etc. I can make it work. But not seeing any motorized mixing values that valve position can be controlled by an external controller.
Maybe i need to look more commercial or industrial sources?
Like this ? Probably others out there.
https://www.supplyhouse.com/Siemens-261-02071-1-NPT-Powermite-MT-Series-3-Way-Mixing-N-O-Valve-Actuator-Assembly-24Vac-10-0-Cv
Or
One Pipe System0 -
That'll work! Also called a supplier and they were super helpful and suggested this: Belimo B313+TR24-SR US
- 50 Industry Classes
