Utica boiler
Is it a bad idea to buy a utica dv100 hrlp used?
    109A_5 Member Posts: 3,963
    How old is it ? Why was it taken out of service ?
  • Forge_Fixer88
    Forge_Fixer88 Member Posts: 20
    That's the data tag.
    Well, it appears a bit old and probably set up for Propane. With that 100 PSI rating the casting may still have some meat to it, hard to say. I would not pay much more than scrap value for it. Certainly a gamble.
  • Forge_Fixer88
    All I know is it was upgraded and someone bought it off the plumber who did it.
  • Forge_Fixer88
    Can't find a whole lot of information on them wanted to see if they have specific issues.
    Due to the age, I would not expect to find much information on it. Old boilers are pretty simple. Usually when the casting / heat exchanger fails (corrosion, rots, or rusts out, cracks, etc.) they are done.
    hot_rod Member Posts: 27,416
    DV is probably a direct vent, so it may require a specific veting material.
    It's really about how it was treated over the years. What type of system it was connected to. Any inhibitors used, etc.
