What parts should I keep on hand ???
Hi all,
Two days ago, I was notified by my oil supplier that because I haven't bought any excessively high priced oil from them recently that they were not going to renew my burner contract. I have been buying oil from their COD division at a cheaper rate than they charge for automatic deliveries—That's not good enough for them as they do not make their fortune as fast. I am also able to find oil on cashheatingoil.com even cheaper than they sell it for. Example—Today's price on their website, CODoil.com is $2.93, on cashheatingoil.com it's $2.64, and if I go with automatic deliveries the price is $3.61—They are ridiculously high. They have also bought out most of the private mom & pop oil companies in the area, as well as one of the longest standing very big oil company—In other words, they are almost a monopoly in this area. A few days before they told me about the burner contract cancellation, I received a renewal in the mail for a ridiculously high price of $609.95—-That's totally & entirely nuts !!!
I have decided to service the burner myself. If I run into a problem, there is a local plumbing & heating guy who serves the local area and helps people who can't solve their problems. I owned 3 service stations for 45 years before I retired and they had a combination of regular oil burners and waste oil burners. I kept them all running for those 45 years without any major problems. My question is, what parts should I keep on hand ??? I figure, a fuel filter, a pump strainer, a nozzle, a set of electrodes, and an electronic ignition transformer. I already have 2 aquastats and a protectorelay. What else is a common failure item for an oil burner ???
Being that my contract expires at the end of this month, I had the overpriced oil company's tech come out and service the burner. He replaced the filter, strainer and nozzle. He put a borescope down the flue pipe to look inside and said the burner is running very clean and he sees no deposit of soot. This boiler (a Weil McLain GO-6) hasn't been vacuumed for 4 years and is still clean inside. He also did a smoke test and came up with zero smoke. So, what else besides what I said above should I keep on hand ???
Thanks,
RON
You have described pretty much what you need. I was also in a similar position. What I also did was collect parts from older burners that I knew to be in good working order. Had a few electrodes, primary controls, fire eyes, fuel pump, coupler, etc., on an old burner or separate and used them as needed. Of course, filters and nozzles where new. If he has an analyzer or a Bacharach kit, you seem to be all set. Just stay vigilant on that oil level and annual service/cleanings.
Do you have natural gas available? If so, might be time to switch………….
We've had the same things happen with oil companies in my area. Whatever happened to antitrust enforcement?
Consulting1
- 167 Indoor-Air Quality
