Rebuild or replace?
JS41190
JS41190 Member Posts: 14
edited October 2025 in Strictly Steam
Is there any rebuild kits for the Richardson vents on a steam vapor-vacuum system, or do people just replace them with a Hoffman _____ ?
    Steamhead Member Posts: 18,463
    edited October 2025
    Replace it. I'd use a Gorton #2. That's on the return line, right?
    Consulting
    JS41190
  • JS41190
    @Steamhead
    Yes, it was on the return.
    Go for it. If there is another vent like this one, replace it with a #2 also.
    Consulting
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,315
    If you need to retain the vacuum aspect, put a teflon ball check valve under it…. we use Apollo 61-104-A1..less spring
    reggi
