Strange Noise
barak
barak Member Posts: 2
Hi. I have been trying to figure out this noise. I can’t share video here because this platform doesn’t let me but willing to connect with whomever would like to share some videos of the noise. Can’t tell if it’s coming from water pipes, valves, or potentially my boiler. I did notice when boiler is not heating, the noise comes up but is intermittent. I have Buderus propane powered boiler and hot water based closed hydronic heating system. Currently, I only use zone to heat water for hot water storage tank. Any help/advice where to start is appreciated.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,094
    Hi, Can you post the video on another platform and link to it? That is an approach others have used 😉
    Yours, Larry
    109A_5 Member Posts: 3,989
    You may have to camp out in the utility room a bit and shut things like the boiler off (no more noise) or stimulate things by running the hot water, dish washer, etc. (for example) to locate the noise.
    As @Larry Weingarten stated there is a bunch of internet places that can host your video, then just post the link here.
  • Peregrine
    Peregrine Member Posts: 32
    edited September 2025
    there is an article and video "15 boiler room noises" by Mr Wohlfarth lower on this front page
  • barak
    https://share.icloud.com/photos/07boOT5HngWnSHF4uA-LmsTTw
    not sure if this would work but this is a video of noise thanks
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Check the boiler system pressure ..
    HVACNUT Member Posts: 7,436
    If the heat isn't on yet, does the noise happen when the water heater is recovering? It sounds like either a circulator, or a cricket on cocaine. Is the domestic hot water ok? Are you able to keep your hand on the indirect circulator while its running? You can put a screwdriver to your ear with the business end on the circulator to pinpoint it.
    I think I heard more 'noise' from the phone (or camera) being hand held than anything else.
