Ruud Monel Water Heater
Scscott9
Scscott9 Member Posts: 2
edited September 25 in Domestic Hot Water
I have a 40 gallon Ruud Monel Water Heater which has started leaking 2 days ago. Plumber advised it needs to be replaced and suggested a Bradford White replacement. Before they remove and dispose, is there value in what I have? Should I retain?
    mattmia2 Member Posts: 15,264
    where is it leaking? unless it is a connection it is done. those have a gas valve that is questionable at best and i believe have the inlet and outlet tubes routed in such a way that you can't put a modern t& p valve on them.
    Scscott9
    The monel might have enough scrap value to be worth taking it to a scrap dealer.
  • Scscott9
    Best I can tell, the leak is coming from the back bottom. However, not 100% certain.
  • Intplm.
    Intplm. Member Posts: 2,800
    edited September 19
    Changing it after all those years is a shame, but a necessity. Bradford white water heaters are terrific. It's time.
  • Intplm.
    It's time for a change.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,989
    edited September 19
    Hi, I do like to keep old heaters going, but safety matters. The gas control and lack of a T&P are reason to consider a new tank. Also it looks like your heater isn't burning well. That tank is probably 50 or 60 years old, so has given good service. Add a second magnesium anode to your new tank, check those rods periodically and you can get fifty years from it. 😉
    Yours, Larry
    ps. I'll add that if the leak can be found, you could use this as a tempering tank to preheat the water going into your new tank.
    i think that design became obsolete by the late 50's, i think it is more like 70-75.
    Intplm.
    EBEBRATT-Ed Member Posts: 19,330
    edited September 19
    hot_rod Member Posts: 26,409
    edited September 19
    looks like some flame roll out from time to time? Time to move on for safety sake if nothing else.
    Do you have any scrap yards nearby, call for scrap prices. I suspect that tank has some sediment in the bottom. You may need to split it open and clean out to get the best scrap $$
    Here is what Al has to say.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,338
    edited September 19
    Back when we made equipment to last ….
    Intplm.
