Ruud Monel Water Heater
I have a 40 gallon Ruud Monel Water Heater which has started leaking 2 days ago. Plumber advised it needs to be replaced and suggested a Bradford White replacement. Before they remove and dispose, is there value in what I have? Should I retain?
The monel might have enough scrap value to be worth taking it to a scrap dealer.
Best I can tell, the leak is coming from the back bottom. However, not 100% certain.
Changing it after all those years is a shame, but a necessity. Bradford white water heaters are terrific. It's time.
Hi, I do like to keep old heaters going, but safety matters. The gas control and lack of a T&P are reason to consider a new tank. Also it looks like your heater isn't burning well. That tank is probably 50 or 60 years old, so has given good service. Add a second magnesium anode to your new tank, check those rods periodically and you can get fifty years from it. 😉
Yours, Larry
ps. I'll add that if the leak can be found, you could use this as a tempering tank to preheat the water going into your new tank.
looks like some flame roll out from time to time? Time to move on for safety sake if nothing else.
Do you have any scrap yards nearby, call for scrap prices. I suspect that tank has some sediment in the bottom. You may need to split it open and clean out to get the best scrap $$
Here is what Al has to say.
