Equalizer size pipe ..
Snowmelt
Member Posts: 1,457
for residential steam boilers up to 75,000-200,000 the boiler says 1.5 inch minimum. I see that a lot of people use 2 inch. Dos the bigger diameter pipe help with the leveling of the water in boiler.?
any other advice/advantage ?
For what it's worth, Peerless allows 1.25"
Just follow the MFG piping drawing for the minimum size.
If you have larger pipe and fittings available that is fine as well.
thanks guys,
- 15.8K Strictly Steam
