PEERLESS WBV-03 Tankless Hot Water Coil Replacement
I need to replace the hot water coil on my aging Peerless WBV-03 oil fired furnace. I'm going to need the part number and the specs so I can purchase the right part. Any info is most appreciated. Thank you! 🛠️
    HVACNUT Member Posts: 7,436
    EBEBRATT-Ed Member Posts: 20,165
    Call TFI Everhot. They make tankless heater coils for all boilers probably have yours in stock. You probably have to buy it from a local supply house but call Everhot with model # of boiler and they will fix you up
    617-924-3877
