for sale barely used Beckett afg f3 burner, Bacharach Smoke tester, Dwyer monometer, fan timer, orbi
I replaced my furnace with heat pump. It was installed new 2003 in florida in 1,100 sq ft house. So, not used a lot. Not used at all when I was away at work. Not used when I was sleeping.
sale:
Beckett afg f3 burner w\new nozzle & new pump. Includes 1 or 2 extra never used nozzles and the perfectly working old pump. New pump & nozzle have less then 1 hour use. pumps: a2va-7116 & 7116B. 200$ w/o used pump. 250$ with both pumps. Electrodes are only a few years old. Also have extra set of electrodes.
Bacharach Smoke tester & 2 packs of papers. used about 50 times. 100$. I bought new 10 years ago and only used it to tune this heater. So, it's basically in new condition. I accidentally bought an extra set of true spot test papers.
orbital flare tool bought new in 2022. used about 10-12 times. 50$
Dwyer model # 400-5 most accurate monometer (more accurate then any digital gauge). No carry case. 100$.
I bought as surplus. It had dried fluid it in. An engineer at Dwyer told me how to clean it out. It has a few cracks in it as purchased, but none breech the fluid area. Both air connectors were totally blocked and Dwyer told me I could just drill them out, as long as gauge is not laid down it is fine. Connectors allow air in either direction but stop fluid from spilling out. Still I bought two new connectors, but never installed them. Uses red fluid is A-101. I have extra fluid, but it is a few years old.
ST9103A electronic fan timer. 75$.
Bought new in 2010 because original was damaged by lightning.
R8184 G originally came with burner 75$.
about 40' new never used oil supply line copper tube tubing/Piping. Ends capped. 25$.
Gauges, as shown free with all above.
Fuel filter housing w\ 2 parker shut offs. Filter contains new filter & includes several extra new never used filters. Also 2 extra filter housings never used. Housings and filters free with all above. The used filter with shutoffs cant be shipped, so pickup only. All bought 2 years ago.
extra high temp sheet gasket material. free with all above.
ask for more pics.
Buyer pays shipping or pickup in st pete florida.
            You had an oil furnace in your home in St Petersburg? To learn more about this professional, click here to visit their ad in Find A Contractor.1
            More curious, what company delivers heating oil down there? 0
            I was in Miami a few years ago, I saw an oil truck on the highway. Needless to say I was surprised and confused. 0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
