Replacements for Apollo ceiling recessed air handlers
I'm having the hardest time finding a suitable replacement for an Apollo Hydroheat H24H hot water air handler. This is mounted in the ceiling, the casing is 35" wide, 24" long and is 11" deep. I looked at First Co, but theirs are all too large width wise. Any manufacturers i should be looking for?
    EdTheHeaterMan Member Posts: 12,132
    I purchases an Apollo Hydro heat years ago. I have since replaced it with a Goodman Air handler and a separate duct coil for the hot water. That does not help you because I had plenty of room to put those other parts together. Sounds like you have to replace something in a tight space. Looks like there is going to be some construction involved with your new AHU.
    EBEBRATT-Ed Member Posts: 20,155
    edited August 2025
    Maybe Majic Air would have something. They make all kinds of stuff.
    You don't hear much about Majic Aire but they make fan coils and AHUs for DX or water
