Water leak at pump
Fordrulz
Fordrulz Member Posts: 1
Hi. I have a Baxi Luna 310 that has error code E10 low pressure quiye often. I see a leak on the lower bolt that holds the pump in. It is a steady drip. The unit is about 12 years old. Has anyone seen this before? Could replacing the o-rings possibly fix my leak or is it a waste of time?
Thanks for any help
    hot_rod Member Posts: 27,446
    See if tightening the bolt stops the leak, first. If not it could need a new pump gasket. We see 15, 20 yer mod con boilers still running strong, on this list.
    Fordrulz
