Any ideas about this valve?
hot_rod
hot_rod Member Posts: 27,302
    mattmia2 Member Posts: 16,430
    looks like it needs a new diaphragm..
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Pneumatic flow/pressure regulator??
    Is the blue hardware behind it part of it?
    EBEBRATT-Ed Member Posts: 20,070
    Does look like a pressure regulator of some type.
    Big Ed_4
    Steamhead Member Posts: 18,394
    How does it connect to the rest of the system?
    Consulting
    It just seems like a lot of casting below where the pipes connect. Ill ask for better pictures
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,066
    Hi, If you're getting more photos, maybe they can find some maker's mark on it. That would help us narrow things down. Aside from the leak, are there any other problems mentioned? 🙏
    Yours, Larry
