The Master Steam Trap Mistake: Why It’s Costly, Dangerous, and Outdated, this weeks video
RayWohlfarth
RayWohlfarth Member Posts: 1,979
edited July 2025 in THE MAIN WALL
While installing a master trap seems like a sound mechanical solution, it causes many other problems.
Ray Wohlfarth
Boiler Lessons
RMyyc
  • JUGHNE
    JUGHNE Member Posts: 11,547
    Good point to make, rad traps are often overlooked.
    I had a system in an older school house that looked like it had a master trap at the cond pump.
    Actually there were 2 systems returning to this pump. The 1954 2 pipe setup had traps at each emitter with EOM F&T……that return went right into the pump.
    The 1920 1 pipe system had the EOM F&T right at the pump as it flowed into the pump also.
    So at first glance this looked to be a master trap for the entire building but was not. FWIW.
  • gerry gill
    gerry gill Member Posts: 3,084
    great instructions
    gwgillplumbingandheating.com
  • RayWohlfarth
    @JUGHNE I'll bet that took some investigation Good find
    @gerry gill Thanks Appreciate it
    Ray Wohlfarth
    Boiler Lessons
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,539
    I loved the video Ray Ray..mad Dog
  • RayWohlfarth
    Thank you my friend
    Ray Wohlfarth
    Boiler Lessons
    mattmia2 Member Posts: 16,692
    outdated? i don't think there was ever time that it was the right solution to a problem…
    Steamhead
  • RayWohlfarth
    @mattmia2 LOL true but it did solve a problem of steam in the boiler room thanks
    Ray Wohlfarth
    Boiler Lessons
