Weil Mclain Boiler Manual
Brian_S
Brian_S Member Posts: 32
I'm searching for a mg/mgb boiler manual for Weil Mclain since I am looking for each boilers rating. Does anyone have or know where I could find one online, also does anyone know if having f or pi as suffixes on weil mclain boilers affects its btu/mbu.
    EdTheHeaterMan Member Posts: 12,018
    edited June 2025
    How old is this boiler. Weil McLain has a Discontinued section to look for older stuff. If I'm not mistaken, I think that was the boiler with round corners on the blue Jacket the was replaced by the LG and the LGB with the square corners on the jacket.
    I was able to find this on e-Bay if you want to buy that piece of old Literature.
    Screenshot 2025-06-05 at 3.16.52 PM.png Screenshot 2025-06-05 at 3.16.36 PM.png
  • ScottSecor
    ScottSecor Member Posts: 1,031
    @Brian S I have some old brochures, catalogs, installation manuals in my office. I notice you are asking about different boilers from last century. We may be able to help if we knew what your goal is.
    Scott
    Brian_S
  • Brian_S
    is there any way you would be able to send me pictures of the ratings og all the old boilers like the bgl, bl, bg, cga, egh, lgb, mgb, etc. Anyhing could help
    edited June 2025
    LGB is here https://www.weil-mclain.com/products/lgb-commercial-gas-boiler-series-2
    EGH. EG. CGa CG are in the Discontinued section here https://www.weil-mclain.com/products/discontinued-products . Once you get to the Discontinued section there is a search box at the upper right… Put in any boiler you are looking for and you may find more than what is on the list.
    Brian_S
  • Brian_S
    Thank you so much I didn't know there was a discontinued products section you just saved me.
    Steamhead Member Posts: 18,394
    @Brian_S , you might also check out the Beacon pages referenced earlier.
    Consulting
