Hydronic air handler not heating
Looking for some advise on how to fix this!
I recently descaled my tankless heater and hydronic air handler connected to it.
Water through the taps is working fine but today I turned on the Heat and no hot air from the vents.
I can hear water moving through the pump and filling in the hydronic coils.
I read online that there might be a air pocket in the pump. But not sure how to bleed it out since there is no air bleed screw. I even tried bleeding it out from the valve on the hydronic furnace.
If you hear it there is probably air trapped in the hydroair coil. There may or may not be the right valves to block flow through the circulator and force flow from the municipal supply through the hydroair coil to purge the air out.
The circulator can just circulate water, it can't lift it through an air pocket in the coil.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
