Recessed radiator
Cindy_06424
Cindy_06424 Member Posts: 1
edited May 2025 in THE MAIN WALL
Need to find how to remove the grill to clean and paint. Any help is greatly appreciated!
    mattmia2 Member Posts: 16,692
    the bottom part is the only part that is a grill, the rest is solid cast iron. What you are looking at is the radiator. some have a little panel to access a steam vent but yours looks like it has hot water trim. i think the bottom grill just snaps in but others will know better than i do.
    EdTheHeaterMan Member Posts: 12,132
    The best way to paint that radiator is just to do it in place. The bottom pressed sheetmetal grill can be removed but is more hassle than it is worth. If you are looking at the two flat head screws on either side about half way up… there are plugs that should not be removed because water will pour out of those openings, if you are successful at removing them which is unlikely
    Put a drop cloth on the floor and wire brush any loose paint or rust that may have accumulated. Then a coat of enamel with a brush or spray can.
    Cindy_06424
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    edited May 2025
    The grill pulls out from the top and lifts off …
    GrallertCindy_06424
    Steamhead Member Posts: 18,469
    edited May 2025
    That's a "Sunrad", made by American-Standard. Here's some info:
    https://www.heatinghelp.com/assets/documents/192.pdf
    Consulting
    mattmia2Cindy_06424
