Granby "Rhino-Tuff" tank (similar to Roth) but with cast aluminum connections
mrblint
mrblint Member Posts: 44
edited May 2025 in Oil Heating
Is there any issue with connecting the incoming metal pipe to cast aluminum threads? Does it require special fittings to prevent galvanic corrosion? There's a galvanized steel fitting that attaches to the cast aluminum threads.
https://www.rhinotufftanks.com/product/190-gal-double-wall-granby-tank/
    EBEBRATT-Ed Member Posts: 20,085
    @mrblint
    Since it is for fuel oil it must be approved for that purpose. I would install it in accordance with the MFG instructions.
  • mrblint
    I'm getting bids for a tank replacement, and just didn't know if that would be an OK design to consider.
    @mrblint
    Granby sells a lot of tanks as does Roth. I wouldn't be concerned.
    heidef
  • mrcoder
    mrcoder Member Posts: 102
    Galvanic corrosion tends to be a problem for water lines. AFAIK for oil lines it is not a problem.
    It does not hurt to apply an oil rated thread sealant (dope). Make sure to leave the end of the pipe thread section ( 2mm maybe) clear, to prevent the dope getting into the oil line.
