bathroom exhaust fan in plaster ceiling
dkmn
dkmn Member Posts: 2
Hello, I need to install a bathroom exhaust fan in a 1959 house with ceiling cable heat and plaster walls,ceiling.Planned on using existing wiring and switch where light is. Can i cut into the plaster ceiling to fit housing of exhaust fan without damaging cable heat?
  • PC7060
    PC7060 Member Posts: 1,762
    you will need to locate the heating cable runs. Recommend using an infrared sensor; you can buy units that attach to smart phone.
    GrallertLong Beach Ed
  • dkmn
    Thanks
    mattmia2 Member Posts: 16,022
    Chip the plaster away carefully with a hammer and screwdriver, if you do it in little chunks you should be able to find the resistance wire before you damage it.
    Test the plaster for asbestos first since a lot of premixed plaster products from that era had asbestos in them.
