Vent on the cold side of water heater when fixtures are lower than heater ?
Dave Carpentier
Dave Carpentier Member Posts: 640
Saw a video recently saying that a vent should be installed on a water heater's inlet side, when a sink or such is lower than the heater.
The notion was that the sink could drain water (if you didnt have supply for some reason) and collapse the heater ?
    EBEBRATT-Ed Member Posts: 20,207
    Could be.
    MA where I am requires a vacuum breaker on the cold water line inlet to a tank type water heater between the cold water isolation valve and the tank.
    I know some states do not require this. Connecticut I think is one of them.
    mattmia2 Member Posts: 16,849
    whichever model code michigan's is adapted from requires a vacuum breaker but only if the inlet to the tank is at the bottom.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,107
    Hi, I'm on the other coast and vacuum breakers are only used here on plastic Marathon tanks. I never see them on glass-lined steel tanks. In the old days, tanks were often made of copper, so the vacuum breaker made good sense.
    Yours, Larry
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,552
    Very rare occurrence. Mad Dog
