The Duke Mansion Mystery
Not long after The Lovely Marianne and I started that little business of ours in 1989, a caretaker called and asked if I would be willing to consult on a problem hot-water-heating system in what he claimed was “the biggest house you will ever see.”
I always love hearing this story.
Dave in Quad Cities, America
http://grandviewdavenport.com1 -
I wonder if the estate is still intact, Dan, would you know? One of my life coaches was a "Led Diables Bleus" (Blue Devil). Academic All-American at Fullback, Mike Mad Dog Curtis #32 (RIP)...Go Blue Devils!!
Mad Dog
Not to defend the plumber but:
In the picture of the joist, the butchered joist is taller than the next one.
Note the top of the windows for scale.
FWIW
From its Swiss cheese appearance, I don't think it's doing much good in any case.
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
The estate is pretty much intact. It is operated by the Doris Duke Foundation as a nature preserve and education center.
I think the chewed up beam is a poured in place concrete beam.
The honeycomb is from small drill holes, and looks like some rebar was in the way also.
In any event not a good deal.
