Tekmar 289
Seems the 289 is the replacement steam controller and I was wondering if anyone has installed one and if they're as good as/ better than the previous version.
Seems there's a pressure input (supposedly to fire a second boiler)- but it looks like it could be tweaked to control a 2 stage gas valve (?)
No takers?
Never used one. Our customers mostly have 269 or 279 controls, and they're doing well.
Consulting1 -
I installed a 289 about a month ago. It's a pretty device with a modern user interface. The big improvement is that it's (finally!) wi-fi enabled. I wanted to take advantage of the pressure transducer input but it's a separate purchase from Tekmar which was backordered and I just received it. I don't think the transducer will help me very much but it's basically a sight glass into the pressure rise and fall and I think it will be interesting to monitor that remotely so I will install it.
I enjoyed the simplicity of the 279, and the 269 for that matter, but Watts had to do something to compete with the functionality of the Heat-Timer MPC and the sudden demand for this Runwise system that's popping up in NYC buildings. Did you have a specific question?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
@JohnNY Mostly looking at general thoughts on the unit compared to the previous versions.
The specific question was using the pressure transducer arrangement to modulate a gas valve rather than firing a second boiler.
Additionally did you use the indoor temp sensors?
I used the outdoor sensor and the system sensor. I don’t have the wiring in place to use an indoor sensor though I’d love to. They tend to make a big difference.
Classes1 -
With this poor resolution of the pressure sensor, I would not expect good pressure based operation of a properly sized boiler. They don't state the actual resolution (that I could find). The picture of the user interface looks like it only goes to 1/10 PSI (2.76" WC) increments, my boiler never even goes that high.
To me Tekmar (more than once) seems one short on the features.
One Pipe System0 -
Saw that. Would be nice if they provided a transducer that went from .5V to 4.5V between 0-5 psi- or less. No one runs a heating system at 15psi anyway. (???)
Breweries and other commercial / industrial applications use the pressure. However in the Tekmar literature they show residential radiators. Optional lower pressure sensors / transducers and software configuration to accommodate them would be better.
You probably could probably use a lower pressure transducer and just do the scaling. So if the Tekmar displays 15 PSI would actually be 5 PSI in the example you used. I think ratiometric, 0.5 to 4.5 VDC transducers are fairly common, not sure about 0 to 5 PSI range.
One Pipe System1 -
Yeah, seems they missed the boat on that one.
- 50 Industry Classes
