Vented LP Wall Heater Help
Ricky122
Ricky122 Member Posts: 1
hello! I have an Empire LP wall heater that I cannot get the thermostat to open up the gas.
I used two different thermostats, even old one that still worked on unit. Thermostat wiring is all new and tested.
AAA battery on wires at thermostat will open up valve so gas valve is working…
please help!
    EBEBRATT-Ed Member Posts: 20,165
    Does this have a thermopile? I don't see a thermocouple.
  • kcopp
    kcopp Member Posts: 4,675
    If it an Empire yes it does… its a powerpile set up. Off to the right.
