Leaking zone valve
Dgocof123
Dgocof123 Member Posts: 3
 I have a leaking zone valve when the valve is open. 20 years old Honeywell vc8715. I need a replacement cartridge for this valve. I'm having trouble finding any information on what will work now in this valve. Do I need to replace it with a new valve?
Thanks
  • mikedo
    mikedo Member Posts: 301
    pictures
    mattmia2 Member Posts: 16,003
    If it is a standard residential honeywell motorized valve the guts can be replaced. If it is the older design you need a retrofit kit that changes it to the type where the actuator can be removed without opening the system.
    hot_rod Member Posts: 27,073
    I think that is the actuator number. Is there a number on the brass valve body?
  • Dgocof123
    I will have to check on the valve body when I return next week but I don't think I saw any more numbers on the body. This valve is about 22 years old. I have a tool ordered to take the guts out. When I do I can post a picture of the valve body and the stem assembly. Thanks
    EBEBRATT-Ed Member Posts: 19,891
    With the age of the valve I would replace the whole thing.
    SuperTechhot_rod
