blockage?
mbu
mbu Member Posts: 2
edited March 2025 in Strictly Steam
I have gas boiler, national radiator#0-4w input 100000btuh out put 80000 I have bled it replaced vales . Once the burner lights and temp starts climbing it starts making noise. Sounds like water flow is blocking . Pressure gage also starts bouncing. I have run a cleaner threw the system. I think it helped a little. Any ideas for me would be appreciated
    EBEBRATT-Ed Member Posts: 20,141
    Water or steam?
    EdTheHeaterMan Member Posts: 12,127
    edited March 2025
    From your description of your problem, I can not tell if you have a hot water boiler or a steam boiler.  They are two completely different contraptions and operate on two completely different principles
    Can you post a photo of your boiler from far enough back so we can see the pipes that connect the boiler to the radiators?
    If it is a water system then you may have a blockage from air in the pipes, and have posted in the Strictly Steam column incorrectly
  • mbu
    mbu Member Posts: 2
    It is water
    Thanks Nick
    mattmia2 Member Posts: 16,658
    Is the circulator working? is the system air bound so it isn't circulating? Sounds like the water isn't circulating for some reason so it is boiling in little pockets in the boiler. Does it heat the house evenly? Are the emitters, baseboard, standing cast iron radiators, convectors, whatever they are getting hot far from the boiler?
  • Grallert
    Grallert Member Posts: 1,111
    You very well could have air somewhere. Air will block the flow of water through you system. Can you here the circulator? At what temperature do you start to here the noise and what temperature does the boiler get to?
    HVACNUT Member Posts: 7,424
    edited March 2025
    Can you post some pics standing back a bit and from different angles?
    Its not gravity? There's a circulator? Do you know if the circulator is running?
    Are there bleeders on the emitters? Pics?
