Oldest Boiler
I’ll take the label if ever you replace it😁
Nice big chest on that HX. No primary-secondary necessary.
That's cool. Could that be some sort of differential bypass coming off the supply and connecting to the return? Is that copper smoke pipe?
I have only visited the San Francisco bay area one time. I was amazed with the climate, never gets hot, never gets cold (compared to New Jersey). Really stupid question, do all homes and commercial buildings actually have heat in this area? I'm guessing not that many houses or businesses are heated with boilers? Am I correct in assuming this antique boiler likely only operates at a small fraction of the time when compared to boilers in my area? Sorry for all the questions.
What is that?
@ScottSecor Yes, all houses here have heating as it gets cold - relatively - in the winter.
If you live close to the SF Bay, you don’t need a/c, but that changes if you travel 10 miles east; 10-15 degrees warmer in the summer and 10-15 degrees colder in the winter.
I have no idea what that device is that @HVACNUT pointed out. Could it be a plugged relief valve?I may have to go back to correct it.
Its piped through from the supply to return. Or return to supply. Some type of bypass or flow restrictor? The Dead Men know exactly what it is.
For sure that gas valve is not original. So a modulating gas valve could have operated from that valve/control thing. Some day when you get back there you may be able to get some closeup shots with numbers or something that might identify it.
"Enquiring minds want to know"
2 -
I’m also wondering about the tank it the attic, if it was capped off.
is that psig or feet of h2o?
-1 -
Must be psig.
@HVACNUT, that looks like part of the control train for a gas actuated gas control system. I only saw a couple of those systems. They were outdated when I started my boiler servicing in 1968. 1/4"od lines went through the limit, safety pilot, low water cut off, if there was one, and ending up at the gas valve where it controlled the gas valve by controlling the movement of a diaphram on the gas valve. They were not a safe control system.
2 -
Someone posted a boiler from about the early 50's here a couple years ago with that type of control where it was all controlled by gas pressure.
The front picture of this boiler makes me warm just looking at it.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
