Testo 310
i have a 10 year old Testo 310 combustion analyzer that has only been used about a dozen times. i bought it to test the combustion on my own steam system. It now tells me the o2 sensor is bad. I peeled it apart with some difficulty and the sensor in the unit is a 0390 0285.
The Testo site does not accept that number. This is the original 310 not the 310-II, does anyone know of a replacement part number? They charge a small fortune so I don't want to just guess
3PSI gauge
I sent my Testo 310 back to them (through my supply house F.W. Webb) when it said that the O2 sensor was bad. They relaced a bunch of stuff and recalibrated it. Yes it was pricey. I wasn't aware that you could replace the sensor yourself. Your whole unit then needs to be recalibrated. My 310 is about 3-4 years old.
- 120 Geothermal
