Rinnai controller readings, flow??
dpenny
Member Posts: 24
What are the units on controller read out for flow rate? I cannot find in any Rinnai manuals, and I have 6 of them.
The quantities are in 20-44 range depending on when filter was cleaned.
I cannot get close enough to circ pump to read it's labels.
What kind of 6 Rinnai's are you talking about? Rinnai makes a lot of models.
Back side of the cover, small paper in the vinyl pouch, it will tell you how to read flow rates, usually 01 is flow rate and you need to a add a decimal point , so 18= 1.8. And 7=.7 gpm
THX. You'd think some of their MANY manuals would tell this fact.
- 167 Indoor-Air Quality
