2-3/4U vs 2-3/4 Static Plate
Robert_H
Robert_H Member Posts: 252
A Weil McLain Gold WTGO-4 that I take care of had high stack temp and was short cycling so this year I brought it down to its lower firing rate of 1.00 vs 1.20GPH "now its a WTGO-4R". Its worked out well especially after getting the draft under control but that's another post. I was going back and double checking my work and noticed that the WM manual for the AFG burners specifies a 2-3/4 static plate for the WTGO-4 and a 2-3/4U for the WTGO-4R. So far I can find no reference differentiating the two. I assume "U" is universal. Is there really a difference?
the table is on page 5 for the curious:
https://www.weil-mclain.com/sites/default/files/field-file/Beckett%20AFG%20Burner%20Manual%20for%20WM%20GO%20Oil%20Boilers%20Series%203%264%20%20%20%20%201220_0.pdf
