LAMARCHE A46-10-24V-A1-12L
PC7060
PC7060 Member Posts: 1,751
edited February 13 in Buy, Sell, Barter
A friend got qty 4 of these 24DC / 10 amp battery chargers / engine starter from an electrical contractor closing out a warehouse.
Any idea of the target application?
Anyone interested, available in Northern Virginia area.
76106719850__6D720561-116C-4B33-91FF-6A300EF4BBFB.jpeg 76106754702__28C3EDB7-0804-417E-9CAA-03CE45F6DCD7.jpeg IMG_8772.jpeg
    Steamhead Member Posts: 18,193
    https://www.lamarchemfg.com/products/a46-battery-charger.html
    Consulting
  • JUGHNE
    JUGHNE Member Posts: 11,513
    We have 2 firetrucks that are surplus from government.
    They use 24 VDC, two 12 volt batteries in series.
    I got 2 24 volt golf cart chargers, maybe 30 amps, put them in a cabinet like you show. Added gauges and time clock to prevent overcharging as these trucks may sit for weeks.
    They have worked for years as a trickle charger…..not engine starting with only 30 amps.
    PC7060
  • PC7060
    I’d send a couple of them to you but the freight bill would be unpleasant!
    Mark N
  • JUGHNE
    Thanks, but no thanks…….they have a "real" copper/iron transformer inside.
    About like picking up a big car battery.
    PC7060
  • Kaos
    Kaos Member Posts: 848
    edited February 14
    That looks like the charger you would use for powered pallet trucks or small forklifts. Mount it on the wall and run a cable with Anderson connectors to connect.
    PC7060
