Frozen pipe in a hot boiler room? This weeks video
When I heard about the frozen pipe, I didnt think much about it. It was bitter cold. Then, I heard the pipe was in the boiler room. Commercial boiler rooms tend to be very warm. How could a pipe freeze in there?
Boiler Lessons
Near the fresh air intake.
I asked a plumbing teacher about that and he said, "We need work in the winter too,"
Ray Wohlfarth
Boiler Lessons0 -
I agree with the air intake diagnosis. We see that often. Solutions (in order of preference) we have used to resolve
-Relocate the water pipe
-Insulate the water pipe
-Heat tape the water pipe
-Relocate the air intake
Automatic boiler room air dampers in the colder weather surely can be the cause of a pipe freeze up in a boiler room. Any type of failure that leaves them open, ie. when louvers become frozen in the open position sure can make a mess. Adding a heat source to the area can help when relocating the pipe(s) is not an option.
Watched the video after posting🙄
Pipe froze outside the heated area & hydraulic pressure opened the weakest part of the line which was in a heated space.
Ive seen this quite a few times in boiler rooms. Its always a draft from outside air and usually on a un-insulated copper pipe.
Entirely possible. We had fire protection sprinkler system installed in a boiler room. It had an atmospheric boiler in the room so it had a louvered opening for combustion air. So naturally the sprink ran the main RIGHT IN FRONT of the louvers. Pure genius. I made him relocate it away from there.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
