stuck steam radistor valve
Mark_122
Mark_122 Member Posts: 5
Any recomedations of how to free a stuck radiator valve? It doesn't seem to want to budge with hand turning pressure. I think someone partially closed it for temperature control but now that room should be warmer. Its a steam system and I replaced the vent valve with a fast venting one.
Thought of spraying the valve with Liquid Wrench or similar but thought it would smell bad for a long time when it got heated.
  • delcrossv
    delcrossv Member Posts: 2,203
    Try loosening the packing nut half a turn and then working the valve handle.
